We just installed it last night....i put in the tide cleaning detergent and put it on santitize. it keeps pausing itself...it was working fine until now. please help
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
SOURCE: Frigidaire Affinity ATF7000ES Front Load Washer Error Message
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug off the mains. You
have to look for screws below the front kick-panel, you can raise the machine a
bit to gain access to the screws, the panel comes down & out. You may find a
drain hose here, on left, drain off the excess water. The pump is on the right
side. Be prepared for dirty water. Inside the big flexible tube (coming from
the tub bottom) is the filter, be prepared to find all sorts of junk here,
clean out. You can pass it into a large plastic bag. Examine your pump also,
clean out the impeller. Carefully refit all. Your machine would be fine. Don’t
wait for the machine to jam to look into your filter.
Pl rate me nice for the free help!
