It's important to ensure that you connect the pink and purple wires correctly to the power inlet contacts on your Schwinn Elliptical 411. Here is how you can determine which wires go to the contacts:
Look for markings on the power inlet and wires: The power inlet may have markings or labels indicating which wire goes to which contact. The pink and purple wires may also have some markings or labels on them.
Check the user manual: The user manual for the Schwinn Elliptical 411 may have a wiring diagram that shows the correct connections for the power inlet and wires.
Use a multimeter: If you are not able to determine the correct connections using the first two methods, you can use a multimeter to test the wires. Set the multimeter to measure resistance and touch the probes to the ends of the pink and purple wires. If the multimeter reading is close to zero, it means the wires are connected correctly. If the reading is very high or infinity, it means the wires are not connected correctly.
Once you have determined which wire goes to which contact, you can solder them together to reattach the power inlet. Make sure the solder joints are strong and secure, and use heat shrink tubing or electrical tape to insulate the connections.
I have had a lot of success searching manufacturer's websites for User's Manuals. Nearly all have them online in PDF format, A second source would be the Sears PartsDirect website.
Jan 24, 2010 - Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to ... Dear Sir: Please ...
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
http://www.kettler.at/fileadmin/user_upload/Homepage/Service/Montageanleitungen/KETTLER-Kadett_7977-900.pdf Try this address. there is usually manuals at the company homepage.
