Resert the code and download your instru. manual and proceed according with the connection diagram appearing use the common sense, logically, and clearly. www.fitness.manualsonline.com God bless you
There are channel select buttons on the front of your tv push those to recieve local stations (if you are watching cable programming look for the cable box remote)
I'd post TV model number first - it's on the back of the TV -and I'd also post a picture if I could.
The lines on the screen do not usually go with the "channel not available" problem and the likelyhood of you having both at the same time is , well, small.
Hi, Let me know is it Toshiba 32A43 tv or any other model? Do you get sound of tv in any input, like dvd playback or cable channels? Can you test voltage in circuit board with multimeter, it will help me to diagnose problem. I'll try best to help you to get this tv fixed. Thanks.
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
