I have lost my instruction but seem to have pictures on my actual camers not on the SD cards - how do I get these off my camera
Two ways:
You may download a copy of the manual here.
SOURCE: sd memory card- on camera
sience they are on your computer try to format the card with the camera. see if you still get the error if you do then try a diffrent card if the camera is still having the issue then you problem lies in the camera's card reader writer. and the main board might need to be replaced. this can run any where from 75.00 and up depending on the full issue. please if you need any further help let me know.
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
