Here is a link to the users manual for your television.
Samsung TXT2793HX XAA Manual
Good luck.
Semper Fi,
Z
SOURCE: Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
SOURCE: magnavox hd2504
try turning the dvd player on,and
inserting a dvd,and then switching
to video the tv has to have a silgnal
when you switch to video the dvd
players splash screen should come
up,and then it will load the dvd
SOURCE: connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
SOURCE: trying to connect a dvd player to the tv
has the television got a/v inputs as most of the dvd players run through a/v rather than coax cable
SOURCE: Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
Connect a set of RCA audio and video cables to the color-coded outputs
on the back of your Samsung VHS/DVD player. The colors of these cables are
yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to
the color-corresponding inputs on your television. When plugging in these
cables, look for a label for the input, such as "Video 1" and
"Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step
3. If you did not take note, you can also tune through your television's input
channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the
"Play" button to verify that the unit is functioning properly.
Component Video
Plug the power cable of the Samsung VHS/DVD player into an available
power outlet near the television.
Connect a set of component video cables to the color-coded outputs on
the back of your Samsung VHS/DVD player. These cables will look similar to
composite audio and video cables, but they are instead color-coded as red, blue
and green.
Plug the other end of the component video cables into the
color-corresponding inputs on your television. Take note of what input number
you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your
VHS/DVD player, then connect the other ends to your television. These cables
are color-coded as red and white and must be plugged into the same input number
as the component video cables.
Tune your television to the component video input channel where you
connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play"
