SOURCE: geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
SOURCE: how do I remove links from geneva wrist watch band
Take a small hammer and a plastic push pin. Look at the pins in your watch. One side will have a line going through the tip of the pin, and the other side may also have that, but it will be less pronounced. Set your watch on a soft surface (couch cushion or cork board, for example) and place the pushpin onto the pin you want to remove. Tap with a hammer until a few millimeters are sticking out on the other side. Take a pair of needlenose pliers and remove the pin. To put a pin back in the band, push it back in until you cannot push anymore, then use your needlenose pliers to push the pin in the rest of the way. Good luck!
