SOURCE: where to get a Samsung s500 usb cable
I can't imagine why in the world you would want to pay an inflated price for another proprietary USB cable. I haven't plugged a camera directly into my computer for years. The last time I did, it was balanced precariously while downloading pictures and got knocked off the table. The USB cable stopped its fall, but the jack in the body of the camera was twisted in the process and completely ruined. A much better option would be to head to your local Comp USA, Best Buy, Radio Shack, etc. and purchase a 9 in 1 card reader. It's a small block of plastic with several slots that will accept a wide variety of memory card formats that have been created over the years. With this single USB device you can read/transfer data from many different devices that you may own. The reader can stay attached to your computer all the time. You simply take the media card out of your camera and plug it into the reader whenever you want to download your pictures. Simple! As an added benefit, you can now make use of that pathetic 128 meg card that came with your camera. Write all your internet accounts, passwords, and other important info to it. Then hide it in a safe place (deposit box) in case of disaster.
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
SOURCE: my samsung L830 camera has jammed with the lens open and
If the lens on the camera is stuck out,
look to see if it's a little crooked. If it is, try to gently
straighten it. If it still won't retract, try to gently push it in as
you turn the power on.
If it won't turn on (the green light blinks and it
beeps 3 times) push and hold the 'power' button and the 'play' button at the
same time for a few seconds - it worked for my S730.
SOURCE: My Samsung L830 Digtal Camera will not come on. I
I can't really tell you what is the problem with your camera. If you have put a new battery in it and it still will not work then it could be any number of things. The best I can offer you is a link to Samsung so you can contact the company directly. When you open up this link I am giving you click on cameras and it will open up another window for you to fill out a contact form where you can explain the problem. Hope this will help you.
http://www.samsung.com/us/info/contactus.html
SOURCE: Samsung Digimax 35 MP3 driver & manual
the driver is available here. Make sure you go right down the page to the large green DOWNLOAD box. Don't click on anything else.
http://download.driverguide.com/driver/Digimax+35+MP3/Samsung/d60211.html
Here you will find the manual the small green box with Download Manual you should click on it's right in front of you when the page loads.
http://www.retrevo.com/s/Samsung-35-MP3-Digital-Cameras-review-manual/id/563ci658/t/1-2/
Testimonial: "All good info. I do want to thank you for your effort. Your comment about $2.99 is so true. Thanks again "
