Error code F2 - 64 even after installing new cartdridge
NEW MACHINE SHARP AR5618 SHOWINGE CODE F2-64
WHAT IS SOLUTION?
my sharp copier ar5618 is showing f2-64.what is the solution
same problem f2 -64 showing in my sharp 5618 how to solve or reset it . plz help me out .
Sharp AR 5618 uses MX-236AT cartridge, ensure that is the pack you have as anything different wont work.
It is also possible that the chip in the cartridge you have bought is fake or bad. The F2-64 error is always associated with the Chip at the back of the toner. You might need to return the cartridge for another one or get a reset chip.
NEW MACHINE SHARP AR5618 SHOWINGE CODE F2-40
WHAT IS SOLUTION?
I found a transformer in my Turbo Chef oven that was Burnt out does that have anything to do with F2!
AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
MY SHARP COPIER AR5618 IS SHOWING F2 40 PLEASE I NEED A CODE TO RESET THIS IS REALLY GIVING ME HARD TIME
How can I get a reset chips
