SOURCE: Nikon Coolpix L11 digital camera won't turn on
if u have cheap batterys in it it might be that try puting some duracellor some good batterys.
SOURCE: Nikon L18 does not work with AA HR6 batteries
Sorry, I had not charged the batteries, Works fine now!!
SOURCE: my nikon s8100 won't turn
It means it has a bad battery since it recognizes power using a different power source. Replace the battery and it should work fine.
SOURCE: Does the Nikon S8100 seem to have more lens error
Not really. It's extremely common on all similar designs from all manufacturers which have retracting/zooming lenses. The trick is to try and prevent the lens from ever being obstructed and to keep the camera in a camera case whenever it's not in use. Also avoid sand/beaches or similar areas as the camera isn't designed to cope with dirt which can get inside due to wind or being dropped.
None are robust, if they fail under warranty they get fixed or replaced. Outside of that you either fix it yourself or bin it and buy another as professional repairs usually cost more than buying another model.
Testimonial: "Thank You!"
