Can i replace it
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt.
You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
CRT Fluid is Cloudy
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Yes you sure can , call electronixs 1-800-223-3205 ask for projection fluid/high purity.
