Cs-4035 with c4200 system error
the C-4200 is as follows for this model:
BD steady-state problem
• The VTC detects a BD error for 600
ms after the polygon motor rotation has been stabilized.
Defective laser diode.
Defective polygon motor.
Defective main PCB.
Solutions:
Replace the LSU (see page 1-6-20).
Replace the main PCB and check for correct operation.
A little hint check the filter in the Bypass or MP tray its at the top and if it is filled with a lot of dust than the Laser is the most likely problem. Their is another filter next to the MP tray to get to this one you have to remove four screws that hold the cover by the MP tray (the side cover). once it is off you will see 2 wire connectors and if you look in the cavity you will see another filter area (probably caked down with dust).
Hope this helps.
