Bands are approx one-tenth inch wide and appear across entire page and affects all colors. It also happens when printing in grey scale. Tried cleaning, alignment, new ink cartridges, different paper, different print qualities. The bands almost appear as one band is in draft printing and the next band is in standard printing.
SOURCE: white bands on color photo prints
Perform Print Head Alignment
Instructions to
perform a Print Head Alignment directly from the machine. If diagrams
or ruled lines are misaligned, print head alignment is required. The
print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually.
Automatic Print Head Alignment
Manual print head alignment
I hope it helps!!!
Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
<1> Example of the pattern with the fewest visible vertical streak
<2> Example of the pattern with the most visible vertical streak
<1> Example of the pattern with the fewest visible horizontal streak
<2> Example of the pattern with the most visible horizontal streak
