LG bd550 and sony bdf5480
Please see the next steps: God bless you
SOURCE: unlock regional code
I found the solution here.
http://www.videohelp.com/dvdhacks/lg-dv480/10008
Region code hack posted by vassmanov, March 23 2009:
Press the Pause button on your remote control. Using your remote control enter the code 3,1,4,1,5 and 9, At this point, a blue screen displays showing that you are in 'region altering mode'. Press the 0 button on your remote control for Region free. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player and your ready to go!
It worked for me (after a few false starts)
SOURCE: unlock region codes
i fund this by dargan and it worked for me "Def" Camino Real 3, Panama:
Region code hack posted by dargan, August 23 2008:
Same hack for DVD283 worked for DVD-277
<clipped from other post>
Region code hack posted by mhardial, January 25 2008:
DVD Regional Codes
Code Location
**1** USA (incl. territories), Canada
2 Europe (Germany), Japan, South Africa
3 Southeast Asia
4 Latin America, Australia, New Zealand
5 Russia, rest of Asia and Africa
6 China
0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6).
6. Press the “Setup” button to exit.
SOURCE: Can't find a regional code to unlock the dvd player.
Insert DVD player, then switch off dvd player, press power botten (On), keep taping 0, it should now load up,
SOURCE: Unlock LG DP450 DVD
hi its a bit late but someone might benefit from this. Make sure that u CLOSE dvd cover.
To multizone:
Make sure that there is no disk in. CLOSE dvd cover. Press power on on remote. if dvd goes into standby press power again. unit will be searching for a disk. as soon as player says NO DISK (heres where u have to guess since the bloody thing is closed) press PAUSE then press 314159 in quickly. Now open and voila the screen will read current region whatever...next press 0 then PAUSE and finally Power key. it worked for me after trying a billion times the 314159 thing.
