Shows not connected - connections are available It worked at the house I got it from ?
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: WIFI
Sounds like one of these problems.
1) The wireless hardware is turned off in the BIOS. Reboot and check to see if there is an entry in the BIOS for the embedded wireless card and if so make sure it is set to ON.
2) The hardware is not recognised because the drivers are not properly installed. Check in DEVICE MANAGER to see if the wireless appears at all, and if it is in an error state. If so, re-install latest drivers from the manufacturer's web site.
3) Other software necessary may be missing. Some machines have wireless manager clients that they need to access the card. Check on the manufacturers' web site for these utilities, and if found, install them and reboot watching for new (different) problems to arise.
4) You could have buggered wireless hardware, but this seems pretty unlikely. Some wireless cards are add-ins and can be removed from the laptop motherboard by accessing them through a door on the bottom of the unit. If that is the case with your machine, power down the unit and remove the wireless card. Check in the hardware manager to make sure no device errors for the card remain, and if they do, remove the hardware by right-clicking on the error device icon and clicking on REMOVE HARDWARE. Then, power down and re-insert the wireless card and reboot and try a clean install.
Good luck...
SOURCE: i connot wifi connection on acer aspire 3610 in windows xp
1. check that the ipo address is set to automatic - not assigned
2. try pinging the router - you may be connected but the dns server may be an issue
SOURCE: it show that my wifi is %100 connected but no server conection
Hi, there are 2 things you can try:-
After each check whether the internet is working:-
First
Start Internet Explorer, ignore page not found
Click Tools --> Internet Options
Click the Connections Tab
Click LAN Settings
Make sure the use proxy server at the bottom is not checked and that Automatically Detect Settings is checked
Second
Try Setting Static IP address, instructions here
http://www.howtofixanything.co.uk/howto-282.html
SOURCE: Acer D150 Netbook - I get a good WIFI signal but
go to my network place then go to local area connection logo and right click on it then go to propeties after that u will see a window crew down to TCP/IP once u are thr click on properties to ur left then fill in the code after than click okay and make local area connection your default connection. thats it u are done
