Kenmore 44102 Front Load Washer Logo
Posted on Jul 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Front load washer didn't complete the cycle.model #44082
I started a wash cycle, signal didn't go off. Went to check why? the washer had 2 minutes left on it , but the softener was still in the tray and the clothes were wet. I tried to start a new cycle and the water will will come in for a few seconds and then shuts off. That is all that the washer will do. The lights are all on, the tray is closed, and the door is closed.
We checked the hoses and there were no kinks.
Marvin
Level 3:
Top Expert:
  • Kenmore Master 85,242 Answers
  • Posted on Jul 06, 2017
Marvin
Kenmore Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024754
Points
266281
Try unplugging the washer for 5 min's and see if it resets, if not call for service.
Pamela Leach
Level 3:
  • Kenmore Master 1,830 Answers
Pamela Leach
Kenmore Master
Level 3:
Answers
1830
Questions
5
Helped
368490
Points
7356
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on Sep 28, 2008
SOURCE: Softener tray filling with water
open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
Anonymous
  • 1028 Answers
  • Posted on Nov 21, 2008
SOURCE: Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Ian Jones
  • 77 Answers
  • Posted on Feb 10, 2009
SOURCE: Black marks on clothing
hi, i think you will find the bearing on the drum is about to fail, you need to replace it, hope this helps
Anonymous
  • 38 Answers
  • Posted on Mar 08, 2009
SOURCE: kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
BOYNISMO
  • 120 Answers
  • Posted on Aug 21, 2009
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
2answers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
3helpful
My front load Kenmore washer 44082 does not start. just buzzes and displays ERR.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Kenmore 44082 washer won't take in fabric softener
Kenmore 44082 front washer will not drain or fill
e23 is not a valid code.
Please re-check and post if you still need help.
6helpful
3answers
My kenmore 417.42042100 model front loading washer is making a loud banging noise during the spin cycle.
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Alexander
vince
