JVC Cybercam GR-DVM90 Mini DV Digital Camcorder Logo
Stevens Yao Posted on Mar 19, 2007
Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
I keep getting the following error message whenever i try to play a tape with my camcorder: E03 Unit in Safeguard Mode - Remove and reattach battery. I tried to remove the battery but it didn't solve the problem. Any advice?
  • 3 more comments
  • fredb22 Dec 02, 2007
    e03 remove and reatach battery i have a rca mini dv cam
  • phodec Aug 20, 2008
    This problem occur in my camera E03 Unit in Safeguard Mode - Remove and reattach battery what should I do?
  • Anonymous Mar 13, 2014
    says on the screen.... E03 unit in safeguard mode
  • Anonymous Mar 14, 2014
    When I turn it on it keeps saying unit in safeguard mode remove and reattach battery
  • James Azure
    James Azure Aug 09, 2018
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 21, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
44418
Points
12
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Anonymous
Level 1:
  • Posted on Mar 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
44418
Points
For the 03 error code my camcorder has been sitting for two years cause did not find soloution i looked on fixya and they gave me idea so i took cassete out flip the record tab back and forth and presto everythingf works fine thx.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
44418
Points
I have the E03 problem and I can't even get the tape out and it clicks all the time PLEASE HELP!!!!!!!!
nico100
Level 1:
  • Posted on Jun 12, 2008
nico100
Contributor
Level 1:
Answers
Questions
0
Helped
44418
Points
I have the same problem E03 noting helps Iam not happy to bring it for repair.
Some body mus know what E03 means?
Pleas help us
Nico
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
48357
Points
18
THIS SEEMS TO WORK... (Do a search of this problem and you will find that every JVC owner is having the same problem.) I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
ChrisIngram.net
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jul 26, 2008
ChrisIngram.net
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
48560
Points
25
Found another web site at: http://www.pechorin.com/m/2007/01/14/Re_E03_Unit_in_safeguard_mode-282363.html that had some solutions to this problem, using a combination of ejecting the tape, removing the battery, then closing the tape but not the door,... etc.
I'll try any method to get it to work.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Anonymous
Level 1:
New Friend:
  • Posted on Aug 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
44418
Points
I have the same or similar problems with two GR-D70E. I could not the reset. Anyone know how to do the reset please?
A
Anonymous
JVC GR-DVL9000E the E03 comes up regardless of whether there is a tape in or not; I have over 80 tapes and not one of them plays or records for more than 5 seconds before the error comes up. I am now looking for the possibility that the sensor is too sensitive, or there is a spring that is over-eager, or some other mechanical failure that causes the error. I need to get this camera fixed; JVC, nor any one else, has ever again built a camera of this high spec. e.g. absolutely the best low light (f1.2 lens), fastest startup (single action - pull out the viewfinder), best stabiliser etc. Regards Hugo
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
52086
Points
11
Day after thanksgiving, (year 2008) about to film my girls putting the tree and same E03 as all of you with the camera chewing my tapes. All of my DV cassettes are brand JVC so I know that was not the issue. I read and read and finally decided to grab a flashlight and study how the mechanism move. Then I noticed something suspicious about the right "two little spikes" attached to a white plastic piece that, when close, it moves to the right side of the camera head (the round stainless wheel inside). The white plastic piece mentioned above, part of it came off the guiding tiny little rail. 1. So I opened the tape compartment with an EJECT command, 2. Close it back up with an inmediate unplug of the camera without battery so it will stay in a position where I can get my fingers and paper clip inside. 3. With the paper clip, stretch the guiding rail in such a way that it widens so the bottom of the white plastic thingy can get back in the guiding rail. 4. Put a cassette inside and FFWD, PLAY or RWD and problem fixed.
Email me if you have any questions. Happy filming!
Raf
3answers
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
When in play mode the following error appears E03 Remove and reattach battery unit in safe mode
As you have already removed the battery and re-attached it, try to clean the contacts between the battery and the camera.
I had tried this and it did not work so I tried Tapping on side of Camcorder ( gently on palm ) and I worked, after 2 or three times while message appeared.
Below are few reasons what causes E03 Error
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with each other, the tape is not wound because of overload to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette having no tape inside.
6. The tape slackens and no pulse is produced until the slack is taken up and the tape comes into the normal
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Error E03. Unit in safeguard.Mode remove and reattach battery. It does not work. What can I do ??
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC's and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
10helpful
3answers
6helpful
4answers
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
3helpful
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
1helpful
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
1helpful
3answers
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
