I start with the normal process...pumping the bubble 6 times, pull trigger and line until attempting to start. Then, once it tries to start, move lever to half choke, then run. However, the trimmer will ONLY stay running if I feather it (heal toe it) back and forth between full choke and half choke. No matter how long, I "warm it up", it will NEVER keep running on "Run". As soon as I turn the lever to Run, it dies. I should also mention that I just changed all fuel lines and filters. The small line goes to the filter and the carb, and the thicker line goes from the bubble back to the tank.
SOURCE: Weedwacker won't start
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
