Question about HP LaserJet P2055d Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
  • Anonymous Mar 12, 2014
    HP m1212 press ok for available media
  • HP Master
  • 1,121 Answers
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Posted on Aug 01, 2012
6ya staff
SOURCE:
pdcameron
SOURCE: Tray which printer prints from.
Just had this problem and stumbled upon how to fix it. Check the guides in your tray 2. Our back guide was slightly off of the proper spot for letter size paper. This was causing the printer to think the tray had a custom size of paper in it. Your document is probably trying to print on letter size paper and when it doesn't think the paper is in there it switches to tray 1.
Posted on May 20, 2010
Anonymous
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
Priya darshan
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
Anonymous
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
Anonymous
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
HP 4350 with a 41.3 error- Paper size is set correctly and size switch actuator is OK. I tried another tray and also tray 1 (manual feed tray). That tray jams- no lift to feed roller. Any ideas?
I have seen many diferent 41.3 errors. Start by making sure tray is set to standard instead of custom and reset machine to factory settings. Next change out the roller assembly behind the tray 1. It has the selonoid on it. I have seen that cause it before. I would just replace the entire tray 1 to solve the no lift. good luck
Apr 08, 2013 | HP LaserJet 4350 Printer
Install black cartridge error message on a hp2055dn printer
error install black cartridge though the cartridge is new and installed properly
Nov 08, 2012 | HP P2055DN LaserJet Monochrome Printer
Hp laserjet p2055dn tray1 manual feed problem
Aug 01, 2012 | HP LaserJet P3005n Printer
I have a " no paper pick up" error message that I
3050 or 3055?
I checked the User Guide for these models; In the error section:
No paper pickup error. The all-in-one has failed to pick up a piece of media.
1. Verify that the media was inserted far enough into the input tray.
2. Reload the media in the input tray and press to continue the job.
3. If the error persists, contact HP Customer Care. See HP Customer Care or the support flyer that came in the all-in-one box.
Under print problems there is some additional information.
The all-in-one does not pull media from the media input tray.
1. The all-in-one might be in manual feed mode.
?? If Manual feed appears on the al lin-one control-panel display, press to print the job.
?? Verify that the all-in-one is not in manual feed mode and print your job again.
2. The pickup roller might be dirty or damaged.
Contact HP Customer Care. See HP Customer Care or the support flyer that came in the all-in-one box.
The setting of 'manual mode' sees the most likely problem of the above. If the setting was not in manual mode, before investigating further you may wish to try a simple reset. Sometimes, restarting the product can clear a paper feed issue. Follow these steps to perform a reset.
Reset the printer
1. Press the Power button ( ) to turn on the product.
2. With the product turned on , disconnect the power cord from the rear of the product.
3. Unplug the power cord from the wall outlet.
4. Wait at least 15 seconds.
6. Plug the power cord back into the wall outlet.
7. Reconnect the power cord to the rear of the product.
8. If the product does not turn on by itself, press the Power button ( ) to turn it on.
If you also see the "Document feeder mispick" Error Message on the Control Panel you might want to refer here: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1140783&prodTypeId=18972&prodSeriesId=1140783&objectID=c01487637
You may also wish to visit this page to have HP auto-check if your driver is current. See right side of page:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=115&prodTypeId=18972&prodSeriesId=1140783
Dec 14, 2010 | HP LaserJet 3050 All-In-One Printer
How to fix error 41.3 on a HP P4515 printer. Have checked all paper settings and tray settings.Changed paper pick up rollers also.
Hi
This error means that the media in tray XX doesn't meet the specified standard of the tray. The specified tray is loaded with media that is longer or shorter in the feed direction than the size configured for the tray. Please check the paper size in current tray or touch OK to change the tray.
To resolve this issue Touch OK to display tray size. Reconfigure the size in the tray so that it uses size of media required for the print job. If the message doesn't clear automatically from the control-panel display, turn the MFP off, and then turn the MFP on.
Restart the printer and repeat the above procedure if issue is not resolved.
Daniel Scott
Jun 14, 2010 | HP Office Equipment & Supplies
Hp lj 4250 tray 1 stoped feeding automatically.
Here is the info from the service manual about tray configuration.
The value corresponds to the media size that is currently loaded in tray 1. ANY: If both the type and size for tray 1 are set to ANY, the printer will pull media from tray 1 first if media is loaded in the tray. A size other than ANY: The printer does not pull from tray 1 unless the type or size of the print job matches the type or size loaded in this tray.
So set both the paper size and type on tray one to "ANY" and you should be good to go.
I hope this helps, if so please rate my solution.
I have the full service manual available for instant download for $6.95 if you are interested.
Buddy
buddy@ccl-la.com
Corporate Computer
WWW.CCL-LA.COM
Jul 09, 2009 | Office Equipment & Supplies
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet P2055d Printer Logo
5,576 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
