You cannot do what you want without the original installer disc that
came with the computer or a later version of OS X installer, unless the
computer came originally with Lion or Mountain Lion.
Follow these instructions step by step to prepare a Mac for sale:
Step One - Back up your data:
A. If you have any Virtual PCs shut them down. They cannot be in their
"fast saved" state. They must be shut down from inside Windows.
B. Clone to an external drive using using
Carbon Copy Cloner.
1. Open Carbon Copy Cloner.
2. Select the
Source volume from the
Select a source drop down menu on the left side.
3. Select the
Destination volume from the
Select a destination drop down menu on the right
side.
4. Click on the
Clone button. If you are prompted about creating a clone of the Recovery HD be
sure to opt for that.
Destination means a freshly erased external backup drive. Source means the internal startup drive. Step Two - Prepare the machine for the new buyer:
1. De-authorize the computer in iTunes! De-authorize both iTunes and Audible accounts.
2, Remove any Open Firmware passwords or Firmware passwords.
3. Turn the brightness full up and volume nearly so.
4. Turn off File Vault, if enabled.
5. Disable iCloud, if enabled: See
What to do with iCloud before selling your computer.
Step Three - Install a fresh OS:
A. Snow Leopard and earlier versions of OS X
1. Insert the original OS X install CD/DVD that came with your computer.
2. Restart the computer while holding down the C key to boot from the CD/DVD.
3. Select Disk Utility from the Utilities menu; repartition and reformat the internal hard drive.
Optionally, click on the
Security button and set the Zero Data option to one-pass.
4. Install OS X.
5. Upon completion
DO NOT restart the computer.
6. Shutdown the computer.
B
. Lion and Mountain Lion (if pre-installed on the computer at purchase*)
Note: You will need an active Internet connection. I suggest using Ethernet if possible because it is three times faster than wireless. 1. Restart the computer while holding down the COMMAND and R keys until the Mac OS X
Utilities window appears.
2. Select Disk Utility from the Mac OS X Utilities window and click on the
Continue button.
3. After DU loads select your startup volume (usually Macintosh HD) from the left side list. Click
on the Erase tab in the DU main window.
4. Set the format type to Mac OS Extended (Journaled.) Optionally, click on the
Security button
5. Click on the
Erase button and wait until the process has completed.
6. Quit DU and return to the Mac OS X Utilities window.
7. Select Reinstall Lion/Mountain Lion and click on the
Install button.
8. Upon completion shutdown the computer.
*If
your computer came with Lion or Mountain Lion pre-installed then you
are entitled to transfer your license once. If you purchased Lion or
Mountain Lion from the App Store then you cannot transfer your license
to another party. In the case of the latter you should install the
original version of OS X that came with your computer. You need to
repartition the hard drive as well as reformat it; this will assure that
the Recovery HD partition is removed. See Step Three above. You may verify these requirements by reviewing your OS X Software License
