Ming A1200 Phonebook Problem - Fail to load/delete
In the phonebook, I created a couple of categories. However, sometimes, when I add a new contact, something goes wrong with the category --- When i go to that category, there are NO contacts visible. When I go back to "All Contacts", all of my contacts are still there. Then, when I try to DELETE that category, it says: "Delete category fail!"
Not only that.. but some of my contacts are messed up now. If i click on a certain contact in my phonebook, it says: "Failed to load contact from phone."
When that person calls me, the name and everything shows up though. When i try to delete that contact, it says: "Delete contact fail!"
I really want to fix this so that my categories and my contacts don't mess up. I have 3 categories I can't delete + about 6 contacts that i can't load/delete
Anyone have any idea on how to fix all this? Thanks for your time!
Re: Ming A1200 Phonebook Problem - Fail to load/delete
Hi ; I have the exactly problem :( please help me I cant find out the solution even I try to copy my contacts to PC but the Motorola software cant read contacts from my phone :(
when you open your address book,select any name which you are gettings in your mobile,after than click on option than edit than got list of that particular name in your mobile
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
With my HTC phone, when I say the key sentence to call one of my favourite contacts (for example, call first contact), my SuperTooth HD says "not in phonebook": You must create your favourite contacts in the phonebook of the SIM card, not in the phonebook of your HTC phone. Once you have created your favourite contacts in the phonebook of the SIM card, please refresh the phonebook of your SuperTooth HD or do the pairing again as indicated below.
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
unfortunately in samsung j700...doesn't provide the facility u mentioned but it allows user to assign particular ringtone and callerid for some group of contacts... the group may have 1 or more contacts so saving each contacts in each seperate group may indirectly met ur requirement
By creating groups of contacts, you can assign ringtones and caller ID photos to each group or send messages and emails to an entire group. Start by creating a group: 1. In Idle mode, press <Menu> → Phonebook → Group → <Options> → Add. 2. Enter a group name and scroll down. 3. To set the caller ID image, press the Centre key → an image category → an image. 4. To set a group ringtone, scroll down and press the Centre key → a ringtone category → a ringtone. 5. Press <Save>.
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays. 3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL. 5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4. 8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook. 10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options: a. To leave the selected key without an association, press the BACK button and return to step 6. b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6. 12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected. 13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE. 15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key. 17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice. 2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays. 2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL. 4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4. 6. Press the MENU button. The associated phonebook entry appears. 7. Press the BACK button. 8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
I have a gravity and when my was giving me similar problems I called there 24 support line and they can basically "refresh" the phone and once they did it to mine it worked fine.........hope it works for you
NOW OPTIONS CONTAINS : NEW EDIT DELETE SEND MESSAGE SEND CONTACT PRINT CATEGORIES SHOW ID HIDE ID ADD DIGITS ATTACH NUMBER COPY --SELECT THIS DELETE ALL PHONE CAPACITY SIM CAPACITY TALK THEN FAX SETUP SHARE PHONEBOOK
NOW COPY SHOWS U ALL ALL OPTIONS::: ENTRIES ALL TO SIM ALL TO PHONE
Motorola E398/Razr address book disappears/bounces:--Solution press 1+# (i.e. speed dial #1) press Menu -> Categories -> Select -> All Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
i cant save contacts or send text out
