I wanted to use the search on QB to look up a clients address. It asked me to load google desktop, i did and found that it wasnt working for me. thee was a option to uninstall google desktop, wich i did. when i went to open QB again it wont open. It loads and asks for my password but a white screen appears and i cannot get in
SOURCE: Quickbooks error ~~ transfering files from 2003 to 2009
There may be more than one issue going on here. In some cases, going to a version that is several versions later requires a stepped upgrade. 2003 to 2004, 2004 to 2006, then to 2009. There may also be data damage existing in the 2003 file that will prevent an upgrade, until it is resolved in 2003.
Intuit used to have a policy that it would have you send in a copy of the data file and would convert it for free if you were going to the latest version.
If you are still unable to resolve this, let me know.
SOURCE: error message " quickbooks has encountered a problem "
1. Do you have a backup of your quickbooks from before this started happening? If yes, try opening the backed up quickbooks file.
2. Uninstall Quickbooks 2009 completely, then reinstall it and check of updates and install all of them, then try it again.
If the problem persists, please let me know so I can continue to help you. These are the first two things to try and would be the easiest solution.
Thanks for using the FixYa forums!
SOURCE: Trying to load QB on my computer
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
SOURCE: Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
