Wiring diagram showing connections for gamecube connection on bike to usb connection on wii console
SOURCE: Gamecube disk stuck in Wii console
If there is a game stuck inside the system, nintendo will want to have it come in for repair so they can safely remove it and get it back to you, if youve had it with in a year they should do the fix for free. Give them a call and see what they have to offer.
SOURCE: wii console not turning on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
185
SOURCE: Wii console connection to computer
2019
SOURCE: Wii board
Make sure that you have synced the board to the wii (similar to a controller). You have to take the battery cover off the board and push the sync button. The blue light will start flashing. From there you need to open the front cover of your wii under the power button.
From there you start up wii fit and it will prompt you to turn on your board. You should get a solid blue light. If you don't, you may need to try syncing again.
