The freezer does not always freezeit It was recharged about 6 months ago and worked fine. The tech said it had a slow leak. If I knew what kind of refrigerant it takes I could recharge it myself.
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
SOURCE: Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
