We can just flashes of light but nothing happens. Has the monitor blown or can it be fixed
SOURCE: Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
SOURCE: Viewsonic E70f 17
Check the horizondal out put transistor if it is short replace the transistoror or replace the flyback transformer.
SOURCE: vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
SOURCE: monitor flashing on and off constantly
You have a problem in your power inverter board. Most likely cause is the FET (field effect transistor) conducting to ground. It controls the backlight for the monitor. Replacement boards are readily available. You can try www.lcdpart.com to order a replacement. Price should between 40-60 USD. It is fairly simple to change. The hardest part is getting the back cover off of the monitor. The part number you will need is right on the board itself. (Be careful not to touch the green cicuit board during the process) It will start with FSP-. It will be the number right at the edge of the board. Be sure to unplug the monitor and allow it to sit and discharge for at least 5 minutes before dis-assembly. This should help most of you folks who's monitors flash in this manner. This is typical for LCD monitors 4+ years old. Merry Christmas!
SOURCE: ViewSonic VA703m 17'' LCD monitor Issue
I would make sure that all the cables are securely connected to both the monitor and the pc computer (screwing the screws from the cable to the port will help hold the cable in). Beyond that, the issue is likely with the monitor and not something that can be fixed by the end user.
If the device is still in warranty (and checking the cables don't work). I would recommend sending it back to ViewSonic to have it fixed.
