Question about Kenneth Cole 1213 Wrist Watch
Kenneth Cole Wrist Watch unable to remove link
How do i remove links on my Kenneth Cole Wrist Watch?
  • 2,338 Answers
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
Anonymous
SOURCE:
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
Need a link for band
  • The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
  • Hope this helps.
Nov 26, 2011 | Kenneth Cole KC3289 Wrist Watch
I just received a new Kenneth Cole watch model KC4646 and the band is too big - I need to remove 2 links - but have no idea how to do this? Help!
Thanks for contacting FixYa.<br /> You can find a simple tuturial here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm">http://www.webwatches.co.uk/how_to.htm</a><br /> <b>Best regards. Jewel</b>
Aug 26, 2010 | Kenneth Cole 1213 Wrist Watch
Remove links, too loose on my wrist
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to add or remove links. Rate me, please.
Mar 31, 2010 | Kenneth Cole Swiss Round Rose Gold Plated...
KENNETH COLE WRIST WATCH MOD. CK1491
Yes, any of the Kenneth Cole dealers will be able to sort out your problem. Check the internet for the nearest Kenneth Cole store in your area and bring the watch to them.
Alternatively you can visit your nearest watch reapair shop and ask for help.
Do not forget to rate, please.
Feb 05, 2009 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole 1213 Wrist Watch Logo
3,736 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
