When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Renault servicecentre and get them to enter this code for you.
SOURCE: need radio code for renault scenic
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
SOURCE: car radio code needed
you need to contact the selling dealer (the dealer that sold the car new, should be in the handbook) and give them the VIN and the should be able to give you the radio code.
SOURCE: i need a code to unlock my car radio could any one
Try asking here
www.ukbookshelf.co.uk
they can provide free Renault codes
Mention this forum
Testimonial: "thanks for the quick response ive now got a new code to try .great forum.quick and easy."
SOURCE: I had to change my battery on renault laguna and now i need the
you must contact car dealer and , may be give them some proof of ownership.They must give you the code.
