Frigidaire ATF6000ES Front Load Washer Logo
Posted on Aug 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire affinity atfb6000es1 e47 - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 03, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466580
Points
5907
Remove the door lockassembly and measure the resistance of the PTC. Shorted or open, defective doorlock assembly. Reads around 1500 ohms, defective Main Control Board.
1helpful
What corrective action for e47 code?
Hello. I need the model number to help you accurately but I'll assume you have a Frigidaire washer. If so, then the E47 code is telling you that the main board thinks the door is open on spin. Go to this web address and it will tell you how to check the electric door lock mech. http://forum.partsdr.com/showthread.php?1-Frigidaire-Washer-E47-Error-Code. If you *don't* have a Frigidaire unit, please post a comment with the brand/model number so I can give you exact information. Thanks!
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Atfb6000es1 frigidaire washer beeps ramdomly
I understand that your Frigidaire washer, model# ATFB6000ES1, is beeping randomly. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if you are hearing your washer randomly beeping. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire front load washer Model ATF7000ES1 (made in 2006) won't spin. Checked hoses and basket, some bobby pins removed. Still won't spin. Error code E47. Checked lock assembly with Ohm meter, read...
Good Afternoon Chris, thank you for your inquiry!
An error code E47 generally means that the door lock assembly may be defective, shorted or open causing the unit to not spin. It can also mean that the main control board has gone bad. Sometimes, resetting power to the unit for about 30 seconds does the trick. If not, you may want to connect with a local servicer who will be best equipped to pinpoint the problem to help reduce the risk of unnecessary parts. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
2answers
Our Frigidaire Affinity washer has error code E47
the error code E47 means your door latch/lock assembly is bad.
Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
