Where is the set up menu to format a memory card
SOURCE: Lumix DMC-TZ3
Memory card likely has temporary(needs formatting) or permanent problems(needs replacing, common for off branded china junk).
First format the mem card on your camera by pressing center Menu button then scrolling down to the end of the menu to Format. If this does not work, and you have bought a Name Brand SD card; Sandisk/Kingston/Patriot etc, return it to place of purchase with receipt, or creditcard use to purchase it, and they will replace it.
SOURCE: says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
