Slipping gears
SOURCE: hobart A200 transmission issues
Your A200 was manufactured in 1942. It may well be time for an overhaul. If it were only noisy, I would suggest re-greasing it, as that would quiet it down somewhat. With 60+ years on the unit, the odds suggest rebuild time. Before you commit to that, take the top cover off the unit, remove two dust covers, insert a hi-intensity flashlight into one hole and look inside the other, look for excessive wear on the gears. If you see excessive wear, and still want to re-build then call for a Hobart tech and warm up your checkbook, OR, pose the re-build question to bigg t (the Hobart tech on this website). He may be able to help you out. ricardok45
SOURCE: hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
SOURCE: The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
SOURCE: hobart v1401 mixer slipping when in 1st gear.
Sounds like the planetary brake needs adjusting or the pin is worn.
