Zenith plasma tv sudden is not getting power. standby light does not come on
SOURCE: zenith plasma
dont get mad like i did, report this problem to zenith, they seem to be aware of the problem with this particular model.
i gave them the model number and they requested the purchase date, then extended the warranty and gave a number for a local repair shop which came for my set a couple days ago.
so far so good. it may be a while until i know whether the repairs will work, however hats off to zenith, so far, which seems to be providing appropriate customer service and standing by their expensive products.
SOURCE: Zenith Plasma TV Manual
I found it posted here
MFL34797058_0.pdf
This is the web site...
http://tv.manualsonline.com/ex/thread/view/idThread/329713
SOURCE: I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Testimonial: "Thank you very much. Quick respnse."
SOURCE: my zenith plasma tv popped real loudlike a car
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Something blew.... like overheated and just basically blew up..... Was it on for a long time? You may to check your warranty to get it fixed or a new one.... or you may have to just buy a new one....
