Question about Maytag Neptune MAH5500B Front Load Washer
One time machine will drain next time won't
  • Maytag Master
  • 17,130 Answers
It is a common fault that the drain fails to work inmost machines in a period of time and is the most problematic fault in awashing machine.This can be a possible failure within the controller unit as it fails to give output to the drain pump. In all occasions it is important that your observation is mostimportant and so is vital to the identification /rectification and solution. Ifyou have noticed that water has leaked then as the drain hose pump/valve andfittings are located on the underside of the machine it is important that youlook for possible leaks here. In some cases the drain hose would be clogged atthe drain end to outlet of the house and so there will be back flushingresulting in overflow to the outside. Also the drain pump/valve can be clogged.Now remove the drain hose clamps and remove the drain pump/valve, clean thedrain pump/valve, use back flushing to clear off all dirt. Now test using powerto see if this works and can be simulated. When refitting, the hose must be tightenedproperly. If the pump/valve does not work even with power then it must bereplaced. If there is intermittent powerto the drain valve/pump then the program controller unit is a suspect.Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use aspirit level- so that all water will drain to the outlet port and thereby thereis no residual water remaining. Replacing the pump on a Bosch machine, please checkthis link for tips:http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Aug 04, 2012
Anonymous
SOURCE:
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My washing machine won't drain...help!
Hi aligrogers,
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
JEDEMEYER1
Jul 31, 2011 | Washing Machines
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
My smart drive model LW015-K top load washer won't drain the water, I think the draining mechanism is blocked but Im not sure. I forwarded to spin cycle to force drain but it just makes a buzzing sound...
sounds like blocked or the pump is shorting out, do not keep using it otherwise the pump can short your board out, get a repairman unless your a handyman
Sep 02, 2017 | Washing Machines
its easy if you know how hahahah the pump either has something jammed in it or its faulty
Jul 21, 2011 | Fisher and Paykel Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
