LT 180 lawn tractor is running rough, needs choke to run
SOURCE: John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
SOURCE: Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
SOURCE: Hello my name is John. I have a 345 John Deere
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
