ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
Posted on Aug 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The ypbpr input is showing up all green
The source YPbPr is connected to DVD but only shows up in green and with weird contrast but the TV monitor color is just fine when you go to the menu
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 05, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292354
Points
3377
Try changing the input device to some other. Look for any loose contacts in RC jacks/sockets/Cable. Check and ensure that the color system selected like PAL/Secam etc. is matching. Try changing the detection of color system to auto mode.
4 Related Answers
Anonymous
  • 271 Answers
  • Posted on Dec 17, 2008
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Anonymous
  • Posted on Sep 14, 2009
SOURCE: no picture
Put new batteries in remote control.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 02, 2009
SOURCE: TV went out over time. Sound immediately, but no Picture
Check the power supply first for bac capacitors (learn more here about bad capacitors: http://en.wikipedia.org/wiki/Capacitor_plague)
I had replaced capacitors in my, hopefully it did not cause damages to other circuits such as backlight inverter board.
Anonymous
  • 59 Answers
  • Posted on Sep 29, 2011
SOURCE: my viewsonic VT2342 LCD monitor/Tv is not showing
I know this sounds weird but you might want to try the remote and see if you may have changed the source accidentally. Like pushing the LINE button on your VCR or DVD player. Just a thought. If all else fails call the manufacturer, they may be generous and give you some help. Viewsonic is one of the best computer monitor folks in the business.
What is wrong with my TV's Ypbpr input???
is this the only input where the TV does this? what happens when you disconnect this source? May be your source.
If the TV does this no matter what input, perhaps you have some leaky caps on the power supply PCB,. These can usually be detected by their bulging tops & usually self replaced (if you have the wherewithall) at a cost of less than $10.00
1helpful
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
REMOTE OPERATES PLAYER BUT NO PICTURE....DO I HAVE IT HOOKED UP RIGHT ???
DVD players generally have 4 possible ways to connect them to a TV set.
1. Composite Base-band Video or RCA's (Yellow, Red, White)
2. S-Video or Super Video (S-Video, Red, White)
3. Component Video or YPbPr (Red, Green, Blue, Red, White)
4. HDMI or High Definition Multimedia Interface (HDMI)
If you are sure that the connections are correct at both ends make sure that the TV set is on the proper input for the DVD player's signal by pressing the input button, source button, or the proper input button as listed (some remotes have a separate button for each input) on the TV remote.
1helpful
Black and white only when playing a DVD or VHS hooked up to my Sony Bravia 32" LCD TV.
What type of connections are you using?
If you are using coax cable check to make sure that the TV is on the proper channel that the DVD/VCR is switched to i.e. 3 or 4.
If you are using Componant video (red, green, blue, and red, white) verify that the green is plugged in all the way on both the TV and DVD/VCR and try connecting it to a different Componant input on the TV.
Note: the TV may be YCbCr, and DVD/VCR YPbPr or vice versa these two types usually are not compatible with each other. YCbCr is a digital signal and YPbPr is an analog signal.
If you are using A/V video cables or (yellow, red, white) check the DVD/VCR video setting to see if it is in progressive scan mode, as this can cause a problem with some TV sets that are not compatible.
1helpful
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. [email protected].
2answers
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
2answers
Connection of Playstation to Digital TV
for PS2 /3 please use the YPbPr inputs. Here is the link for the cable: http://www.sourcingmap.com/4in1-component-ypbpr-video-cable-for-ps23-wii-xbox360-p-10240.html
Best regards,
Arpi
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
