Computers & Internet Logo
Ankit Suthar Posted on Aug 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automatic restart problem
Any time my Intel dh55tc motherboard automatic restart problem. i will try troubleshooting step. 1.new hdd install 2.new smps install 3.replesh the CPU & motherboard 4.new ram change 5.bios not s update only 6.windows xp reinstall 7. ram slot chang. not a solution for restart PC. Plsase solution? Thank You. Ankit Suthar
  • Gulzar Cherichiyil
    Gulzar Cherichiyil Aug 04, 2012
    When it's is restarting,  before os installation or after?   If after,  any interval, ? Like 5min 10min?
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Aug 04, 2012
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5664277
Points
79191
If the PSU power supply units fan is not working the PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
4 Related Answers
Anonymous
  • 10406 Answers
  • Posted on Sep 26, 2010
SOURCE: Dear friends... I have a (assembled
The "high-low" (or "ping-pong") sound is a warning from the motherboard about some problem, usually overheating of the CPU, or one of the fans is either not working, or it's spinning "too slow" (before its specifications).
Turn the computer off.
Open the case, and try to spin the fans.
If one fan has seized, or does not spin freely, replace it.
Techbelkin
  • 358 Answers
  • Posted on Nov 02, 2010
SOURCE: I have pc with these specifications Computer Type
Hi here is the link you needed for download your drivers .
click my name to go to the link and download.
Techbelkin
Anonymous
  • 4 Answers
  • Posted on Dec 18, 2010
SOURCE: Hi , my name is
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Anonymous
  • 3 Answers
  • Posted on Feb 11, 2011
SOURCE: Problem: Windows xp Sp2 or 3 installation
I HAVE THE SAME PROBLEM, AND I RESOLVE IT CHANGIN A BULGING CAPACITOR NEAR THE PROCESSOR
Dh55tc warranty check
do the following steps to rectify your problem.
1.if there are any beeps. clean your ram and reinsert it.
2.check the power cord of your monitor and make sure you have a working monitor.
3. else buy a vga card if the onboard vga slot is malfunctioning
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
1helpful
Intel DH55TC Motherboard does not recognize the internal dvd burner in BIOS
Update your MOBOs BIOS. also check the connection points on the mobo to see the SATA connection is impeded or messed up in any way.
I just installed a BLKD915GVWBL LGA 775 Intel 915GV Intel motherboard in a new computer i'm building. everything powers up but no video. i have tried 3 different moniters. what's the problem?
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Remove any VGA/Graphics card that you have installed. Also remove any PCI cards that you have installed.
6)Connect the monitors VGS cable to the Blue 15 pin female VGA out port of the motherboard.
7) If possible login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Note: Please click on ' Accept' to accept my answer because it is your Acceptance, which gives us motivation to assist you with more efficiency.
1helpful
My motherboard have a prablem meens chipset intel very hot and no eny pictuer in monitor
5) Login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
Now restart the PC and see what you get.
My computer does not start after installing new smps
its a very old motherbord.
1. check your smps is working.
2 . why you bought your new smps, broblem with older one, older one might have also damaged your motherbord .
3. if not try your old smps.
4. check ram etc.
5. if nothing work out time to buy a new one or second hand.
Restart issue.
Some steps:
1.check if your motherboard fan is working.
2. reseat the RAM after cleaning its point of contact using an eraser.
3. if it doesn't solve this problem try taking motherboard and SMPS to a shop for check up and repair.
1helpful
3answers
I have Intel DH55TC Mother Board cannot get display when i remove ram from board board get beep & i also change ram but same problems
Always Provide Proper Details.
1. Processor
2. Motherboard
3. RAM With Company Name
4. Graphics Card Detail
After Reading Ur Comments I Want 2 Know How Many Beeps You Hear....
Beep Details.......
2 Beeps Shows Graphics Problem
Use PCI-E Graphics Card Like ATI OR NViDiA.
3 Beeps Shows RAM Problem
Use Another RAM OR Try The RAM In Another Slot OR Channel.
Hope This Helps....
Grand Canyon Tech
Grand Canyon Tech
