When i want to delete photos from my camer it shows"this memory card is writed-protected"
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I did this to memory card and camera still says 'this picture cannot be deleted'. Why is this happening??
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
SOURCE: my DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
SOURCE: memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
SOURCE: The camera says Memory card is write protected and
If it is an SD memory card, check for a little white tab on the left side. Chances are that somehow it got pushed down to the 'write protect' mode. Move it back up and you should be good to go! Good luck.
Card Data Recovery is professional photo recovery software to recover deleted, lost, corrupted or
formatted photos, videos, and auido files from various memory cards, such as,
SDHC card, SD card, CF card, memory card, memory sticks, USB devices, digital
cameras, hard drives, and zip drives.
http://www.card-data-recovery.com
