Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
My Whirlpool duet sport washing machine is 2.5 years old and recently started having error codes now it makes clicking and grinding noises when I try to start a wash cycle. Once the door locks usually water comes into the machine and it starts to spin, now I only have the noises and no movement or water. Has anyone else experienced anything like this before...could it posssibly be that the pully is broken? Thanks for you input!
  • 100 Answers
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 17, 2008
6ya staff
SOURCE:
Whirlpool duet sport, fabric softener is not working
you probably have a clogged tube from some old softener that dryed up inside it
Feb 25, 2015 | Whirlpool Duet Sport HT WFW8400TE Washer
SOS: We bought a used Whirlpool Duet sport washer and dryer, which the owners said were about 2 1/2 to 3 years old. We do not have manual for it so cannot figure out why the washing machine window blinks...
F-20 on display (Water Inlet Problem-no water or insufficient water supply)
  1. Select PAUSE/CANCEL twice to cancel the cycle.
  2. Unplug washer or disconnect power.
  3. Are water faucets completely turned on?
  4. Are screens at inlet hose connection clear of obstructions.
To view the manual in an Adobe PDF format right click and select open to go to the owner's manual site.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8400TE&siteCd=MT_EN_US&userType=Consumer
Feb 22, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Wirlpool Duet Sport Washer shows no indication of power
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel.
There is a test you can run...look in the manual.
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport. Will not start in any setting.
Get a sledge-hammer to within 2 metres of the washing machine. Then go for the button on the right side "end of cycle" & depress it with your finger for 3 seconds, the control light will come off & I hope you will be able to use your machine.
PS. Remove the sledge-hammer.
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
964 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
