No buttons are being pressed on the Tv or the remotes. Just keeps going on and off repetitively
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote
select the Reset option. Using the right arrow button at this point
will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
SOURCE: my tv keeps clicking and won,t turn on
This is a fault and the unit requires service, please refer to the Samsung website for the country you are residing to arrnage a service.
SOURCE: NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
