The screen looks good for initial 1 min, but after that snow comes on the screen.
SOURCE: Sony Bravia LCD KDL32M3000 picture going dark
Sounds like it may be the backlight ballast on the inverter. Hopefully you are still under warranty, Call customer support even if you are out of warranty and explain problem.
In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
In Spanish: 1-800-222-7669 - Follow the (English) voice path for your product, and then select the option for Spanish support
Hours: Mon-Fri 9:00AM-10:00PM / Sat 10:30AM-7:15PM EST
If they can't help let me know and we can diagnose the problem together. Let me know if this helps and please rate this solution. LOne99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
I already tried , connecting my bravia, Laptop using HDMI cable in that also i am facing the same problem.Please suggest any other solution if you have. Thanks for responding
