Well if you have a top loader then one or more of these bungies have broken: If you have front loaders then a stablizer is like a shock on a car, with any luck you just have to locate it and snap it back in place. They come loose when someone washs tennis shoes or the washer is simply moved to another location.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Located on top of the machine. You must remove the front panel and then raise the top. . Check out the pic:
Use a putty knife in between the front and top to spring the front panel off. Get mean with it if you have to. Then remove the screws holding down the top. Raise it up and you will see the bungies. Even if they are not broken they are stretched. replace them.
i have top loader where are these bungies located?
are they easy to replace?
