My washer will not turn on ive check power supply and all that stuff, ive heard there is fuses in the power module but dont know where that is
Unplug from the wall. in the motor control module, remove the screws holding it down. mark and remove the connectors. carefully lifting it out, flip it over,to the warranty sticker. pop it in half, and you will see wires soldered to the back of the board with a fuse holder. 5a 250v
Hello and welcome. Couple things to check first-
Tip the machine back and look underneath at the water pump, if it is wet or appears crusty/corroded, you probably have a shorted pump that took the machine control out along with it. Sometimes you can just replace the pump but on those models the board can become a casualty. Also look at the control itself and check for water in the pan area underneath it. Sometimes the mixing chamber thermistor leaks and it will short out the machine control. Whenever you replace the control, a new seal should be put on the thermistor. (easy and cheap insurance)
You might want to start with a fisher paykel gwl11 service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=17
