Also not draning comlpeatly showes OE and a red key in a circle
OE on the LG means the washer is not draining or has a draining issue. When it happened to me I started by manually draining the washer and then running a spin cycle. In a pinch the work around was OK but I could never be certain the wash was complete. Also the wife hated it.
Finally, I dug in and went for a fix. All the hoses were clear and the pump seemed to be working (also the pump screen needed clearing). I found the problem to be a breather hose that runs from the top of the drum to one of the drain hoses. It was plugged and I took it off and blew it out. Problem solved.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
heatman101
