Mitsubishi dlp wd62628/tv will work fine and all of a sudden the right side of picture will go black. Left half of program continues normally. We then will turn the tv off, then turn it back on with tv remote, wait for the power light to stop blinking green and when solid green will then turn it back on with cable remote. Picture comes back normal and then a while later will happen again. Please advise. tguinan
Sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Same Problem just started at Power On with our 2 year old DLP Mitsubishi WD 52628. Has happened about 6 times in past week. Sometimes takes several power off/on cycles then all is seemingly OK. Any suggestions before we get the repair shop here after the Holiday? Thanks
