We had paused a movie but when we were ready to resume the movie the picture was very dim and dark....we thought we heard a pop before this happened and screen was completey dark for awhile, but when we went to watch the movie again it was very dim
SOURCE: LG 50PX1D (Popping noise)
Hi you need the y-sus board. You May find it @ partstore.com Thanks.
Testimonial: "Thank you, can I fix this myself?"
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: LG 42PC3D Plasma: No picture, good sound
One of the SUS panels will be defect.On these panels you will find several fuses,the panel with the broken fuse must be replaced.
Sus panels are the panels with the big cooling blocks.
SOURCE: LG 50PX4DR 50 in. Plasma TV/DVR Combo popping
The pop sound was due to any component failure.
Most probably the capacitor. Depending upon the size the sound is produced.
The
first step of diagnosis is checking the fuse. The boards of the plasma
tv are very costly and in most of the case non-repairable. The only way
out would be replacing the ones required.If you want to repair it
yourself then you should be having proper knowledge about the internal
circuitry of the plasma TVs as they are totally different from tubes and
lcds.
You should also require a multimeter and soldering equipments.
It is not possible to say which board because the diagnosis has to be done step by step.
You will have to check the PSU output and Y board and Z board input.
Most probably you will need to replace Y,Z and Ctrl board unless there is virtual defect.
Let me know,if you wanted to repair it yourself. I would be glad to help you further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I have a lg model
I will put this out there and I have this same issue on a daily basis. The popping sound is a capacitor that has gone bad, the second pop is a capacitor that shorted out becuse of the first one that went bad.
The boards that are responsible for this are the X and Y sustainer boards, they are what creat the picture on the screen and this is why you have sound but no picture. This is a very very common issue with plazma tv's. You must replace both of these boards together or the bad one will short out the good one!
Yo can google these parts and will find a host of people selling them, so look around and get the best deal. Don't get used or rebuilt, get new with a warranty. They are very easy to swap out, they are the two boards, one on each side of the display.
If you need more help with this let me know, tere are instructions available but it really is an easy job, just make sure the set is unplugged for at least an hour before touching anyhing inside.
