Dynex DX-LCD32-09 LCD TV Logo
M J Silver Posted on Aug 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
I have run auto at least 10 times. 130+ channels takes a long time. but when the scan is done - a box with the words "please run channel setup auto scan" stays on screen. I have repeatedly run the auto scan and the message box "Please....auto scan" keeps coming back. How do I get rid or stop the "auto scan" request? We have charter cable tv.
  • 2 more comments
  • Diana Covell Feb 20, 2014
    I HAVE THE SAME PROBLEM!!! VERY FRUSTRATING!!!!
  • Fidel Rubio
    Fidel Rubio May 06, 2014
    you have RESET television on the first menu screen as the tv will not detect the antenna input unless it is already plugged once the reset is carried out
  • Renae May 17, 2017
    What if you're not plugging into a cable box or antenna and you just want to use your bluray player?
    What if you're not trying to plug into a cable box or an antenna and you just use it through a bluray player
Ricky brashear
Level 2:
Sergeant:
  • Expert 176 Answers
  • Posted on Aug 06, 2012
Ricky brashear
Expert
Level 2:
Sergeant:
Answers
176
Questions
0
Helped
89447
Points
529
For some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
4 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 23, 2010
SOURCE: My tv keeps saying to run auto channel scan.
FIRST, you must check ALL antenna connection, and if possible, try another "Known Good" antenna system. If it proves that the antenna system is all OK, then I fear your Tuner, has failed, this is a common event, that I get from time to time at my shop. Usually, it is a straight forward job and the cost would be about $250 - $350, depending exactly what is going on. However it would be best to get a "Quote" first, before proceeding, as this may only be a symptom, of a larger underlying problem, that may indeed cost much more.
Anonymous
  • Posted on Dec 25, 2009
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
BeckiB_DISH
Becki Barned
  • 286 Answers
  • Posted on Sep 01, 2011
SOURCE: Hi, I have the Dynex
There are a few things that can cause this. This may be an issue with the TV itself or with how your DISH Network is set up. Are you able to change channels at all; with the remote or the panel buttons? There are many things that we would need to go over. But you will want to make sure that your DISH is connected tightly to the TV. Please email me so that we can get this resolved!!!!
Becki Barned
DISH Network Customer Service
[email protected]
Anonymous
  • 2049 Answers
  • Posted on Sep 04, 2009
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
1helpful
2answers
How do I run a channel auto scan on a Coby TV?
It will be in the setup menu. I believe with the Coby there is an initial setup screen which will guide you through.
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
1helpful
2answers
It ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
