Has picture for one second then black has sound all the time
The board will be hard to locate but run between 80- 150 if you can find them. However your symptom is most likley cause by one of the Transformers. Which you can get replacement transformers from www.tvrepairworld.com send them a email from their website by hitting the contact button on the right side.
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: [email protected]. (866) 839-5888
SOURCE: LVM-37w1 Westinghouse lcd has picture for 3seconds
Hello, I can assure you it is the inverter board on this unit. The T-CON board (controller) will only mess with your picture in different ways but you the way you describe the symptoms it is for sure your inverter board. The harders part wil be to find some, you should probably look in www.shopjimmy.com, or www.invertercentral.com.
