Televison & Video Logo
Posted on Aug 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE CHANGE MY TV EPROM I NEED TV CODE TO SETUP
NEED SERVICE CODE FOR SANYO TV
Anonymous
Level 2:
Scholar:
  • Expert 64 Answers
  • Posted on Aug 06, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
64
Questions
Helped
39623
Points
205
NOTICE: MUST READ BEFORE USING SERVICE CODES!!! RiddledTV.com provides this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes. * Unplug the power cable. * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet. * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. * Use the {CH+} {CH-} buttons to select menus. * Use the {VOL+} {VOL -} buttons to change settings. * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data. * Press the {MENU} button or turn the TV off to exit.
Have a Sanyo tv and volume not working it's poping up unsupported something about codec
HELLO,
Check out ebay and your model tv for repair kits, I think I saw one for a Sanyo tv replacing eprom. Cost around 15 bucks
Need code for urc-3300im to a sanyo tv
0381,0389,0385. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
2answers
NEED A CODE FOR A SANYO CRT TV WITH A SANYO REMOTE
0854,0347,0223,0548,0532. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Sanyo 26'DP26648 tv need tv code
You're in need for a universal remote setup code for this TV, I assumes and posts this solution. The setup codes for Sanyo brand TVs are given below. If you want more details about the setup proceedings, and more codes, check this link.
0049 0097 0110 0004 0268 0012 0108 0180
NEED CODE FOR SANYO TV DS19500 REMOTE CONTROL
Universal remote setup codes for Sanyo TV are: 0049 0097 0110 0004 0268 0012 0108 0180
1helpful
2answers
Codes for Sanyo HDtv
Hello
Setup code for Sanyo TV with one for all URC-3021 remote control is:
0154
The other four digit codes to check with Sanyo TV with universal remote control are:
OK.
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Philips rear projection TV model 60P8342.
It`s not Eprompt, it`s the Eprom, Erasable Read Only Memory. The Eprom holds all the information in it about your set like has it got Ni-cam Sound, A wide-screen, A projection set plus a lot of other information like Convergence settings, RGB setup, PAL, NTSC settings plus customer settings like Colour, brightness etc. There are other settings besides these which are in binary bit code which can control the power supply, Standby timing etc etc. The Eprom may only be an eight or a sixteen pin device but it a crucial part of the set where information is perminantly being read from the Eprom to make sure the three guns are set correctly and the convergence errors are being kept in check. This is a very time consuming job even for a qualified technician, I know, I used to do these and Philips sets are notorious for Eprom and uPC failures. The Eprom comes formatted from the suppliers, so there`s absolutley no information in it at all meaning that you have to start from zero. If you can get the set to come on long enough and you can get the set into service mode, you may be lucky where you can write down the 200-300 or so settings, If not, WHAT A JOB. Believe me, you can change the Eprom in 2 minutes, but it could take 1 or 2 days to set it all up again and even then it`s very difficult to get it perfect. Ian
Sanyo 32" Tv about 4 yers old problem
Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
Vertical height oversize
The eprom was found to be faulty (nvm)
Pressing the screen format button displays wide, smart, zoom and 4:3 modes but settings have no effect on picure
Enter TT35 in the service mode to select a 4:3 CRT
My Sanyo DS24425 24 inch screen moves slightly to the left and stays there. its very frustrating because i play games on that tellie and cant see part. it's not parted halfway though. its like one a couple...
The problem can be corrected by only qualified technician. There is what is called the service man's menu which can only be accessed by a partciular code in service manual for that particular TV. Your local service technician should be able to locate the the manual and then perform what is caller a horizontal centering adjustment. In today's tv's there are no alalog controls for easy adjustment, it all done with eprom ic which allows the manufacturer to use the same chasis for many different picture tube sizes. If you could get manual. and have basic computer skills , you could probably do it yourself. You might try ordering the maual from Tritrinics/Cititrinix 1-800-638-3328. Scrivitron
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
