Question about Fisher and Paykel Washing Machines
We have a Fisher and Paykel washing machine model MW509NZ. it keeps going into error with Leds 3, 5, 7 and 8 illuminated and a beeping noise. What is the problem please.
    Master:
  • Fisher and P... Master
  • 745 Answers
This is a fault code 43 which mean the out of balance switch is either faulty or the switch isstuck in the on positionfree up or replace switch which is located just under the main board
Posted on Apr 21, 2018
6ya staff
SOURCE:
pfergy
SOURCE: Fisher & Paykel Smartdrive 701 Model GW701-U
Hi mate
I had the same problem replaced the board still no go. In my case it turned out to be the drain pump. Nothing wrong with it but a small bit of grit that although difficult to see was impeding the impeller
chee3s
Pul
Posted on Dec 11, 2007
l blight
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
Anonymous
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
Anonymous
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
Anonymous
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
That is fault code 43
Here is the info for 43
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel MW 512 AU is not running. The first and the last lights(long wash and spin leds) on the displays stays ON in red and keeps on beeping. I appreciate any help in resolving this issue
This(130) is the only code that comes close to that,
There is no code for 129.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 26, 2012 | Fisher and Paykel Washing Machines
Our FnP GW611 while filling the water stops and starts and after a short time it stops and beeps and the long wash and spin lights come on orange. Any ideas? Thanks
The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
Aug 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1...
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher paykel eco smart is GWL11 not GWL15
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
