SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
SOURCE: sewing machine 'popped', and needle is hitting
Adjust the metal plate to fix the needle hitting problem.
SOURCE: My sewing machine makes whirring noises but will
Not sure about this model but most have a belt inside the machine to connect the motor to the rest of the machine. Some have an access plate you can remove. New belts are available many places and are usually easily replaced. Good luck
SOURCE: My Handwheel on Brother LX
sounds like you have the bobbin clutch disengaged. Check to make sure you have flipped it back to sewing mode.
