It slowly stopped working compressor is hot though
SOURCE: Frigidaire Freezer is not getting cold LFFU1765DW9
try to vacum the coils on back, if thats the problem u will feel them get a little warm if this doesnt work try to tap the relay next to your compressor, i had this same problem
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
SOURCE: frigidaire upright freezer MFU20F3GW7 (model)runs
Clean cooling coils....throughly. Check door seals.
SOURCE: FRIGIDAIRE UPRIGHT FREEZER COMPRESSOR VERY HOT
Well I finally found the screws for the front grill. The compressor started cooling off once the seal was put back in place. So I'm going to give that a day or so. Still did not find the coils I'm assuming that they are in the sides. One thing I do know for sure, is that I'm putting you guys in my favorites. I educated myself so much from your website. I'm not sure I ever had a problem except the seal. I don't have the original motor to check but I'm working on getting it back. If I would have found this website before the tech I would have saved $150.00. Thank you so much.
Hello Tana - Freezer might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
