Sound and picture work on all input types (HDMI/composite/...), just with the addition of color horizontal "snow" which is appreciable bad. The set was manufactured in 2008 and was purchased at Costco. It has been a very nice set up until a few days ago. Any suggestions on what needs swapped?
Can you post a picture that shows what snow issue is that youre experiencing that would help with diagnosis
It sounds like a DMD chip problem. White dot syndrome gives off problems like this. You can read more
sorry -- got cut off trying to post my answer. After reading this, it sounds like a DMD chip problem. White dot syndrome will give you that snowy picture. Usually you need to take it to a technician and ask for a repair. To check if it is white dot syndrome, look at this articlehttp://www.fixyourdlp.com/2012/06/01/the...
After reading this, it sounds like a DMD chip problem. White dot syndrome will give you that snowy picture. Usually you need to take it to a technician and ask for a repair. To check if it is white dot syndrome, look at this article http://www.fixyourdlp.com/2012/06/01/the-affordable-solution-for-the-dlp-tv-white-dot-problem/
SOURCE: Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
SOURCE: Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
SOURCE: I have a kdl52b5100 bravia. I can not get a
Chances are you have a BU Board that has failed. The only way to know for sure is to get a Qualified Service Person out to verify the symptom.
Sony's Customer Service Phone # is
1800-222-SONY.
I hope this helps,
Skyassoc
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
